Martin's Aircraft Factory RV-8
Date:  3-14-2016
Number of Hours:  3.00
Manual Reference:  DWG 64
Brief Description:  Fuselage - Center Section assembly
This afternoon, from 14h30 until 17h30, I worked on assembling the center section again. I riveted F804L RH and LH, then installed the vertical bars F804G per drawing. It turned out the AN426AD4-14 rivets called out on drawing appears to be too short. I didn't not get an appropriate bucked end on the rivets, much too small. Will likely replace those rivets.
