Martin's Aircraft Factory RV-8
Date: 12-18-2015
Number of Hours: 0.00
Brief Description: Shop Supplies - Reception Replacement Part order f
On this day, I received the following replacement parts from Van's Aircraft:
- F445 Flap Bearing Block, Qty (3) (1 for replacement, 2 for spare part stock) - F802C-L-1 L/G box web, L/H (to cancel/replace the L/G MOD I did previously) - F802C-R-1, L/G box web, R/H - F802E-L-1 - F802E-R-1 - F802F-R-1 - F802F-L-1 - F866B Upper FWD Baggage bulkhead, to redo Avionic Access Hatch mod. - F800 angle, to put in stock if ever needed - Aluminum C Channel, to eventualy redo F863-1 brackets L/H and R/H - F814C-R-1 inboard seat rib angle - F814C-L-1, inboard seat rib angle
and also....
a 2016 Van's Aircraft Calendar to decorate my work shop !
Copyright © 2001-2020 Matronics. All Rights Reserved. |
