Martin's Aircraft Factory RV-8
Date:  12-14-2015
Brief Description:  Fuselage - Seat Rib structure dimpling
More action on the seat rib sub assembly that day ! I did:
- Finalized dimpling started previous day on skin panel F827-1
- With the seat rib on saw horse, up side up, I check all the potential nutplate location for removal seat floor mod. I noted on structure where I shall install one lug nutplate.
- Following this, I unclecoed the entire seat rib structure in preparation for dimpling skin panel F826 and F827 mating parts, and also for adding nut plate holes for removable floor mod.
- I scuffed all the surfaces prior to dimpling parts.
I worked from 16h45 until 18h00, then from 19h45 until 21h15
