Martin's Aircraft Factory RV-8
Date:  12-11-2015
Manual Reference:  DWG 77
Brief Description:  Fuselage - Match drill F837 & Rear Seat Hinge on f
This Friday evening, returning to work after that session with my uncle Jean-Louis, I turned my attention to more fitting parts on seat floor assemblies. I did:
a) For the Aft Control Mount Support F837-1
- Match drill dia #12 the Aft Control mount support F837-1 with the Floors F829-1, F830-1 and F831-1 plus the inboard seat rib F814A-1 L/H and R/H
- Removed the parts and deburred the holes
- Using my nutplate jig, I added the holes dia #40 in F814A-1 L/H and R/H for the nutplate K1000-3 to be installed at a later time (ref DWG 77, detail B)
NOTES: Due to bolt hole dia #12 being larger than the pilot pin dia #19 on nut plate jig, one set of nutplate river hole dia #40 was drilled with an angle relative to the axis line of F814C-R-1. This error was esthetical only, and it was deemed acceptable at the time. Nevertheless, the angle F814C-R-1 was eventually replaced, and those holes were redrilled in line and perfect.
b) Rear Seat Hinge final fit:
- open holes full size dia #30
- Create a 0.025" thick spacer shim to level hinge on floor F831-1 relative to Floor F830-1
c) F830-1 and F831-1 Floor assembly: match drill all dia #40 holes common with underfloor angles
I worked from 19h00 until 21h30
