Martin's Aircraft Factory RV-8
Date:  12-1-2015
Number of Hours:  1.00
Manual Reference:  DWG 64 and 65
Brief Description:  Fuselage - Center Section & Seat Rib Assy
During that working session, I did:
- For Fuselage Center Section F804, I finalized installation of 12 AN4 bolts in FWD F804A-1, in lieu of RV-8A L/G attachment brackets. (Ref DWG 64)
- I started working on the Seat Rib Assy (Ref DWG 65, instruction pages 8-12 to 8-14). First task done was to cleco parts F814C on F814A, both LH and RH, then the rear spar F806 parts together.
- I took the opportunity to review the instruction for installation of Aileron Electric Trim, as suggested on instruction page 8-12. I reviewed the drawing supplied with the Aileron Electric Trim. I noted that this engineering drawing is somewhat out dated. It is more relevant for RV-8 fuselage "Dash 0", and not the more recent "pre-punched Dash 1" version of today
I worked from 20h00 to 21h45
no pics
