Martin's Aircraft Factory RV-8
Date:  11-24-2015
Number of Hours:  3.00
Manual Reference:  DWG 63
Brief Description:  Fuselage - FWD baggage bay floor & bulkhead
ow, I am working on the FWD Fuse sub-structure (Ref: DWG 63), continuing on the FWD Baggage Bay Floor panel, then on the LWR and UPPER FWD Baggage Bay Bulkhead. I did that day:
- Match drill F870B-1 and F870E-1 with skin Panel F820 LH and RH
- Scuffed F870B-1 and F870E-1
- Dimple F870B-1 and F870E-1
- Bulkheads F866A and F866B match drilled with F802N Cross brace, hole deburred and dimpled
In addition, I worked on FWD Floor Assy parts (Ref DWG 61)
- Drilled all dia #40 holes full size & deburr on parts F802L-1 and F802K-1
- Scuffed these parts
I worked from 15h00 until 18h15
no pics
