Mark Weitkamp CX4
Date:  10-10-2019
Number of Hours:  10.00
Brief Description:  finished cutting out bulkhead blanks, added rib to
Finished cutting out the remaining bulkhead blanks. used the bandsaw to cut them out, sandwiched between the form blocks currently cut to full size, including flange allowance. Next step will be to cut off the flange allowances, round the edges, and use the form blocks to shape the bulkheads and bulkhead components to final shape. also still need to debur the edges of the blanks, and shape some of the more intricate flange arrangements on station 3 and station 5. Also today went back to the center section, removed the wings for installation of the remaining ribs, and got one rib clecoed into place.
using the bandsaw to cut out bulkhead blanks
bulkhead blanks laid out on the wing
adding another rib to the center section
