Mark Weitkamp CX4
Date:  3-20-2011
Number of Hours:  4.00
Brief Description:  up drilled rivet holes to # 30
I got all the rivet holes for the bottom skins on the left wing drilled up to # 30 size. I also installed the aft wing spar and the aft wing spar reinforcement bar. Next step on this wing is removing the protective plastic from the skins, deburring all the holes, and riveting the skins on.
