I had tried engine start the night before. I seemed obvious that there was a fuel issue. I started troubleshooting the fuel system. Disconnecting hoses and running a fuel flow test with the electric pump. Found a miss made fitting at the red cube. It still had a punch out in the hole. Removed that, reconnected every hose, checked for leaks and then wheeled it out and it started right up. Sounds good. Checked for leaks and had none. Added screws to the fuse to wing lower skin. Added the EXPERIMENTAL decal to the engine compartment. Finished fitting the strobe/ nav lights and lenses to the tips.
