I finished cutting the Garmin GDU370 holes in the panel. I received the wiring I ordered from Aeroled to power the rudder strobe. I ran this wire and then realized I had forgot a wire for the Magnetometer in the tail. I ran that wire and then started tidiying up the wiring. I am wanting to get the tail cone area finished so I can rivet on the rear skins. I alodined all the remaining skins and then remembered I needed to get the rudder cables run before I rivet the skins. They won't show up until the finish kit comes in next week. At least this part is done for when the kit shows up. I spent some time cleaning up and vacuuming before clecoing the skin. I also received my B&C electrical supplies so this weekend I can run the headset and mic. plugs and wiring. Also received all the switches so I can temporarliy mount them in the panel.
