Sanded th inlet ramps that I had put micro on last night. Changed the bolt for the mixture because it had been hitting the inside of the cowl. Then re-installed the cowl and checked fit. Added micro to the nose of the cowl. Removed the masking from the windsceen and the first layer of tape. I am very happy with the fairing. A little more final sanding with 320 and it will be ready for paint.
