Worked on the canopy frame fit all day. Most builders complain about this part of the build. I figured that it wouldn't be that bad. I figued I would be able to outsmart it. I figured wrong. This thing was a pain in the ass. I believe that by the end of the day I had it close enough. I will check it again tomorrow to make sure I am happy with it. I then drilled and screwed the rear slider track in place to make sure everything was straight. I moved to the next step on the canopy and drew the center line to help find the handle hole location.
