Added the top skin and match drilled it all. Drilled the center rib to the firewall in assembly. Fabricated the little brackets for the vents. Drilled the vents and brackets and temp installed. Decided to jump in for a little ride. Pulled the top skin back off and drilled the panel attack angles.
