Today was about tip ribs. Drilled ribs and checked fit. Removed, trimmed ribs to fit with th hinges, epoxied into place with only clecoes. Once the epoxy was mostly dry I riveted the ribs. Sanded the rivet lines and added a layer of epoxy and fiberglass so rivets won't show through the paint. I got both tips done with riveting and one side each with fiberglass.
Finished riveting all the parts to the tip so added strips of fiberglass over the rivets
