Marks RV-9 build Site
Date:  11-1-2011
Brief Description:  Started L. elevator assembly
Started L. Elevator assembly. Riveted spar re-enforcement plates, nut plates, root rib, horn weldment and top skin stiffeners. I used a different jig to spread the skins to back rivet the stiffeners. The new jig worked much better and I am happy the way this skin is turning out. I will rivet the skin to the spar tomorrow and hope the final results are better than the R. elevator.
