Marks RV-9 build Site
Date:  10-9-2011
Number of Hours:  10.00
Brief Description:  HS riveted
Needed to stay qyuite this morning until it got a little later so I started working on the rudder.
Started cutting stiffeners and removing plastic. Match drill the stiffeners for the right side.
When it got a little later I moved back to the HS. Riveted in the forward spar in both halves. Then the rear spar. Only have the back side rear spar to finish squeezing in.
HS 95% complete
HS 95% complete
Started working on Rudder stiffeners
