I primed all of the HS ribs and spars. I received my order from Avery Tools but the replacement C Frame dimple shaft was wrong again. I still need to dimple and prime the skin. I have gone as far as I can on the HS until I get the correct part from Avery. So I started the VS. I got the skeleton assembled and match drilled. Then clecoed on the skin. I got one side match drilled and then gave up for the night. I emailed Avery about the problem early so they could get the correct part out quickly. By 3:00 I had not heard from them so I called. They hadn't bothered to get the shaft out today so it won't ship until tomorrow. I will be disappointed if it doesn't show by Friday.
