Marks RV-9 build Site
Date:  11-9-2011
Number of Hours:  3.00
Brief Description:  Finished up Emp.
Installed counter balance lead weights and fitted elevators to HS. This took installing and removing about thirty times to get the fit right. I wanted to make sure the gap and fit was good before I drilled the center hinge. Mounted the trim tab and connected the trim servo. I will probably wait on the fiberglass tips until later. This means I am finished with the emp kit and will wait around for the wing kit.
