Marks Web Site
Date:  8-8-2009
Number of Hours:  4.75
Manual Reference:  8-x
Brief Description:  ELT installation...
I started the day by riveting on the ELT mount reinforcing plate, bolting on the ELT mount and strapping in the ELT. Next I fabricated a bracket to support the end of the aft fuselage wiring harness support rail and riveted on the bracket. Then I attached a D-sub connector to the wires for the elevator trim servo and mounted the connector to the bulhead forward of the ELT. Lastly I bolted on the seat belt upper attach point restraint cable.
ELT mounted
ELT mounted
Wiring support rail bracket attached
Seat belt upper attach point cable installed
