Marks Web Site
Date:  5-19-2009
Number of Hours:  4.00
Manual Reference:  8-x
Brief Description:  Magnetometer installation...
After having installed the magnetometer mount some days ago I had not yet installed the magnetometer itself so I started the day by doing that. Then I continued with the lighting installation I started yesterday. I installed the canopy, mounted the magnetic compass and routed the wiring for the compass light through the glareshield. Next I prepared the bottom of the glareshield for a LED light strip and then bonded the light strip to the glareshield. To finish off for the day I drilled the holes in the instrument panel for the left and right map light and on/off switch and trial fit the right light and switch.
Magnetometer and connector secured on the mount
Installed the compass and bonded on the glareshield LED light strip
Map light and on/off switch installed
