Marks Web Site
Date:  3-25-2009
Number of Hours:  8.00
Manual Reference:  8-x
Brief Description:  Fuel and electrical system component installation
I carried on from yesterdays work session by modifying my fuel system firewall fitting mounting blocks to a four bolt retention system. I also did this to the engine manifold pressure distribution system. Then I turned to the electrical system by fabricating the cables from the main buss to the essential buss diode. Next I fabricated the cable from the essential buss for the essential buss solenoid. Finally I fabricated a hat section to mount the hot battery buss. I installed anchor nuts on the hat section, riveted the hat section to the firewall and installed the hot battery buss.
Fuel system firewall fitting mounting blocks modified to four bolt retention
Main buss to essential buss diode cable with fuses installed
Hat section fabricated and installed with hot battery buss installed
