Marks Web Site
Date:  12-3-2008
Number of Hours:  4.00
Manual Reference:  10-5
Brief Description:  Nose wheel fairing iterations
I returned to the nose gear fairings after having primed and reassembled the metal components. I had not yet riveted on the nut plates to secure the forward section to the aft section of the wheel fairing so I riveted those on. I found the gear leg fairing attachment clamp interfered with the forward wheel faing section when the wheel was fully turned so I trimmed away the glass where the interference occurred and glassed on a blister to accommodate the clamp. Then I also glassed in doublers for the aft wheel fairing section at the mounting screws followed by countersinking once the glass had cured. I also countersunk the screw holes for the forward wheel fairing section.
Nose gear leg and wheel fairings installed
Nose wheel fairing forward section blister added
Wheel fairing aft section screw hole doubler added
