Marks Web Site
Date:  6-14-2008
Number of Hours:  3.75
Manual Reference:  10-1
Brief Description:  Left wheel and brake assembly mounting
Today I fabricated the spacers for the left wheel fairing mounting bracket, bolted on the axle flange, brake mounting bracket, wheel fairing mounting bracket and the brake. Then I installed the wheel and wheel spacers and checked the clearance between the brake disc and wheel fairing mounting bracket. There was insufficient clearance so I had to dismantle everything and add a washer between the wheel fairing mounting bracket and the wheel fairing mounting bracket spacers. After reassembly the required clearance was acheived.
Left wheel and brake assembly mounted
