Marks Web Site
Date:  10-20-2009
Number of Hours:  3.00
Manual Reference:  13-1
Brief Description:  Wing tip fairing primer and UV blocker applied
In the morning before going to work I sanded and then primed the wing tip fairings a second time. While the primer was drying I sanded the nose wheel fairing. Then I was out of time and went to work. Later after I was back from work I abraded the primer I sprayed ealier in the day and applied the UV blocker.
Wing tip fairing sprayed with a second primer coat
Wing tip fairing UV blocker applied
