Marks Web Site
Date:  1-5-2007
Number of Hours:  4.00
Manual Reference:  7-6
Brief Description:  Left wing tank Z bracket preparation
I continued working on the left wing tank attachment brackets. I match drilled them to the spar and drilled them for the nut plate holes, see image 1. The inboard Z bracket has the nut plates attached to the spar instead so the spar was prepared for the nut plate installation, see image 2. Finally the tank was clecoed together to check the fit with all the interfaces, see image 3.
