Marks Web Site
Date:  10-13-2009
Number of Hours:  3.00
Manual Reference:  13-1
Brief Description:  Elevator painting preparations
I was going to clean, etch and abrade the elevators today but after looking at the fairing installation I decided the fairings needed work first so I did some sanding then mixed up some micro and did some filling. While I had the epoxy out I also bonded on a flange on the engine cooling plenum aft left corner where I had previously added on an extension to close the gap that was there. Then while the epoxy cured I worked some on the engine manifold pressure supply line due to an outstanding issue not dealt with yet. Then it was time to quit and go to work.
Elevators sanded and micro applied
Engine cooling plenum aft left corner flange bonded on
