Marks Web Site
Date:  8-16-2009
Number of Hours:  3.50
Manual Reference:  8-x
Brief Description:  Elevator trim wiring & stab fairing installation
Today I bolted on the horizontal stabilizer one more time to finalize the elevator trim wiring from the trim servo to the aft fuselage bulkhead disconnect. I added snap bushings for the wiring pass through, cut the wires to length, added heat shrink for extra chafe protection and then crimped on D-sub connector pins. Then I bolted on the vertical stabilizer and began the fitting of the upper and lower stabilizer fairings.
Elevator trim wiring routed from the trim servo to bulkhead disconnect
Stabilizer fairing fitting started
