BushCaddy ELSA
Date:  10-29-2007
Number of Hours:  1.00
Manual Reference:  none
Brief Description:  Static ports
I installed a static port on each side of the fuselage aft of bulkhead 2. I purchased the two fittings from aircraft spruce Part # 10-00250. Laid out rivet pattern for four rivets and drilled and deburred them. Centered the static port in skin between bulkhead 2 and 3 and drilled center hole and inserted static port and drilled out rivet holes, deburred and riveted in place. Installed 3/8 OD plastic tubing on each static port and used a tee to run the tubing forward under the gauge panel. Fabricated mount for the fuel valve.
Static port on right fuselage
Static poet tubing and tee on left side
Still need to run tubing forward and secure
