Brief Description: Rudder pedals and front cabin skins
Placed cabin on table after removing the landing gear brackets for next faze of drawings. Drilled backer plates and bolt holes for rudder pedals and riveted in place after deburring and priming. Installed rudder pedals as per drawing with the exception of the spacing stated in the drawings. The spacing between the pedals should be 140mm not the 90 stated in the drawings. Checked alignment of rudders pedals for cable to UHMW by door. Removed rudder pedals and started on cabin outside skins and glare shield. A lot of measuring and drilling completed now it will be time for de-burring and priming. Front outside skin and glare shield drilled for rivets.
