Drilled 3/4" hole for PF-185 and bolt holes. I did not attach at this time as its bolts go through the PF-190 & PF-191 and the cabin frame on each side. Placed skylight in different places for best visibility and decided to place were Bushcaddy had suggested. The second stringer PF-183 is removed if you are installing a skylight. I did turn the second PF-183 around so the smooth edge was against the skylight. Cut and bent PF-185 and PF-184 as per drawings leaving a tab for the top side and internal. See tip # 4. Deburred all holes and primed all parts. I riveted PF-184 & PF-183 to PF-190 & PF-191. When you are cutting and bending the frames be sure to not make them to tight or you can push the top of PF-190 & PF191 out. Check to make sure you maintain the width of the top.
