Completed the top leading edge and bottom gap seals for the right wing. I ran out of nut plates again so I will pick some up at the Arlington Fly-In. Installed the cargo area covers and fuselage lower corners. Installed ELT under right seat and installed antenna in top right wing gap seal. Finished wiring connector plug and running wires for right nav and strobe lights. Secured Communication antenna wire in fuselage.
