Brief Description: Began riviting the Left HS together
The process of putting the understructure together with the skins gets underway. I darn near ran out of cleco's. This work was prior to placing the forward spar in place which had to wait until the 707 rib is riveted. You can't get to it once the skionis on.
Note, it helps if the flanges are little greater than level so that the skin compress them and causes them to lie flat. If you don't allow for this, a small gap can occur. It's probably a nit, but then again, I'm my own worst nit picker.
The 707/8 ribs clecoed together
The 706 rib clecoed to the skin
The skin held in place by the clecos, prior to riveting.
