Brief Description: Set the wing incidence, sweep, and measured twenty
Ready to drill the rear spar holes. The following data is set for the wings:
Left Wing: Aft hole tip to tail = 154 4/16 nches. Left Wing: Fwd hole (2 back) tip to tail = 181 14/16 nches. Right Wing: Aft hole tip to tail = 154 5/16 nches. Right Wing: Fwd hole (2 back) tip to tail = 181 15/16 nches.
Sweep is 0 degrees. Using plumb bobs (4) and the above measurements
