Set the position of the sensor and secured it to the vertical support behind the flap motor. While testing the flap motor actuator separated from the eyeball fastener at the base. This has been a problem area for RV's. It will be reinstalled as soon as I complete wiring to the sensor D-Sub connector and the VP unit.
