Brief Description: New attempt using aluminum angles to get correct a
This attempt has promise, but the selected location doesn't have enough room for my hand to get in and tighten the nuts to hold the panel down.
What I've done is used a foam core board, lightweight but stiff, so it won't warp and fastened the magnatometers side by side on it. The angles are on the ends, but they require another angle to fasten them down to the aircraft. Now,the assembly doesn't quite fit in this location. Back to the drawing board.
