Brief Description: Completed riveting right lower wing skin.
NOTE: Be careful when bucking inbetween the ribs when there lightening holes in the spar. The damn bar will fall thru the hole and onto the leading edge. It will take an hour to retrieve. Don't ask how I know this. Tip - a little shovel cut onto a small piece of aluminum, about 3 - 4 feet long will get under the bar. Then with duct tape folded into a two way sticky sheet, place the tape on a more substantial piece of alumiminum and slide it uner the shovel bar combo. Remove the shovel and gently bring the aluminum piece with the bar out of the wing end. Lots of fun!
