Brief Description: Reprimed the aileron brackets and mounted the fuse
My thanks to Scott Seagraves for the rotating fixture. Although it didn't fit, some more mods, with parts bought from Lowes (again) made the fit possible. Taking a strap of steel and using it as extension of the mounting plates, it worked perfect. Standoffs were used where the bolts came out of the mtor mounts so the bolt head would not hit the firewall. This design also allows access for installing parts on the firewall.
