Rick's RV-7A Web Site
RV-7A
Trim tab buildup
The trim tab spar was drilled, dimpled, and fitted with the tab hinge which was also drilled after very careful alignment. Also, the control horn brackets were fabricated.
Trim tab hinge and control horn
Fitting the control horn
Initial test fit of the trim tab
RV-7A Home
3159
Baffles
234
475
338
Flight Controls
708
Instrument Panel
Landing gear
77
234
Lighting
Smoke System
Systems
Windshield
