Cut out leading edge for plexiglass lens and installed Kuntzleman Landing/Taxi/Recognition LED light. Installed bracket so it can be removed from lens opening if necessary. Last picture shows Steel A-Frame that I have in my shop. I found it very convenient to be able to lift the tail up in the air while working on the aft fuselage. I was able to lift the tail high enough where I could actually stand up in the aft fuselage
