Mark,(Onex 35) and I took Todd's(Onex 68) idea and came up with a little different version for attaching the trim springs to the elevator control rod. We did not like the idea of just clamping the springs to the control tube. Mark cut the pieces and I welded them up, one for me and on for Mark. Will put a thin piece of rubber between the brackets and control tube and clamp the bracket to the tube.
One view of brackets
another view-made from 4140 steel tubing and welde with ER70s
Brackets willl go here to replace original set up.
