Brief Description: Completing Paddle Assemblies and Skinning Wings
Completed left paddle assembly and started skinning the right outer wing assembly. Cut notch in rear inboard spar to allow for outer wing to fold into closed position. Could not tell from the drawing if the notch included the vertical part of the spar so I did not remove that part. Once the wing was skinned it closed into the notch with a snug fit which I think it should be.
Left inboard paddle assy
Straps pulling the skin into position. Used 1 strap perpendicular to the long ones to help square up
