Brief Description: Assembling Right Outboard Wing Panel Substructure
Started assmebling right outboard wing panel substructure. Enlarged openings in rib position 6 so paddles would pass through freely. Most material was removed from the top of windows but also took about 1/16" off bottom. The paddles did not hit the bottom-I just wanted a little more clearance.
Rib positions 6 and 7 assembled
Windows for paddle assembly enlargeed
Provided a little more clearance at the bottom of windows also.
