Brief Description: Calibrated Oil Pressure and Oil Temp
Made a temporary setup to verify oil pressure filling up tubing that goes to oil pressure sensor with oil and then applying air pressure to line. Varied the air pressure with regulator and watched pressure change on Dynon Skyview display. When oil pressure go low warning light appeared on display. Works as designed
Oil temp is displaying ambient temperature in shop so that does not change but I am satified it is working as the temperature is much colder in the morning before the shop warms up.
Oil pressure and temp displayed.-50 psi and 63 deg.
Oil pressure low-alarm flashes and when alarm is acknowledged, problem list show up.
