Brief Description: Modified Boat Trailer to Haul My Onex
Modified a single axle boat trailer to haul N331EX. Cut the back cross brace out of trailer and welded pivot point up near the front. Made ramps out of 8 " channel iron and tail wheel landing pad out of 10 " channel(would not have to be that wide, just happened to have a short piece lying around). I used the hand winch to pull the plane up the ramp and then raise the ramp with scissor jacks that are welded to the bottom of the ramp. Used cordless drill to operate the scissor jacks. Once the ramps are up level, I have a piece of pipe that slides in underneath the ramps to hold them up. Retract scissor jacks, tie down the plane and ready to go. I can easily load and unload the plane by myself.
