Lorens Web Site
Date: 4-6-2013
Number of Hours: 10.00
Brief Description: Started Wiring Panel
Received panel back from powder coating and started to do final wiring, I had previously installed the power buss and temporarily installed the panel to test all my lighting circuits. I have a solid copper ground buss on opposite side from power buss. Installed circuit breakers, switches, MGL V6 Radio and Dynon Skyview EFIS. Finalized wiring all lighting circuits and check out fine. I am very happy with the AVEO Flash LSA lighting system and Kuntzleman Landing/Taxi/ Recognition Lights. Powered up the V6 radio and tested TX/RX with my wife on my Icom handheld. So far, so good.
Still have to get all the inputs to Dynon_ADHARS, EGT, CHT, Oil Pressure, Oil Temp, OAT, Transponder. etc.
Panel back from powder coating
Power distribution bus
Panel mounted in cockpit
