Brief Description: Took Measurements fo 7:0:1 Compression Ratio
Temporary install of cylinders for compression ratio. I decided to go with 7:0:1 so I could use car gas. Had one jug that did not fit well into case(you can seebluing in picture 2) and had to do a little sanding. Packed case with rags to keep sanding fines out. Held jugs in place with two spacers and nuts snugged down for taking measurements. Ended up with .250 " worth of shims. Note: make sure you clean up the shimis before installing-they a stamped and have rough edges that could allow for oil leaks at base of cylinder.
Checking amount piston rises above cylinder at TDC
