Brief Description: Installed Rudder Pedals and Rudder Cable Pulleys
I am just shy of 6 ft tall and this is where I placed my rudder pedals. Had to remove some rivets from sidewall on lower longeron inb order to move mounting blocks back. You will save yourself some work if you locate the rudder pedals before installing all rivets on the lower forward fuselage.
Bottom of picture is firewall looking down into cockpit
