Added 4 ( four) Wiing Pivot Doubler Angles as per Dwgs ONX-W19 & W20. These were not on original drawings so I am glad that I had not done the final riviting of the wing skins. Rechecked torqe and applied torque seal to threaded fasteners. Installed short aileron rod and hardware to outboard bellcrank.
Added angle as per Revision A
Torque seal applied
Attached hardware and short aileron rod to bellcrank
