Brief Description: Grind Clearance for Short Aileron Rod in Outboard
Forgot to mention this in an earlier post. I found that I had to grind a little more clearance in the spar for the short aileron rod to pass through without rubbing on the spar. This should be done before skinning the wings as it will be difficult to do after the wing is skinned. Material removed from ONX-W18-16
