Assembled control stick sub assembly. Removed powder coating as per plan and installed aileron and elvator control stick. Note to builders: If you haven't installed you main spar into the fuselage yet, it would be much easier to updrill the holes for the bearing blocks prior to installing the the main spar. In fact I would assemble the control stick sub assembly on the spar with temporary bolts before sliding the spar in.
